Date/Time: Sat, 18 May 2024 05:59:18 +0000
Spreadsheet columns
View Count: 697
[2018-09-11 00:58:59] |
User444031 - Posts: 3 |
Hello, I can not find in help how to add columns, also how to change order of columns in a spreadsheet. Please help. Thanks, Simon |
[2018-09-11 02:59:15] |
Are you referring to a spreadsheet when using the Spreadsheet Study? What specific columns are you referring to?
[2018-09-11 19:44:14] |
Just regular heading columns, like volume high low etc. When I opened a new spreadsheet some data columns were already there, I wanted to know if there are more I can add or create, and if I can change their order. Thanks Simon |
[2018-09-11 21:27:09] |
Here is the documentation for the Spreadsheet Study: Overview of Spreadsheet Studies You can add additional columns by adding studies with the data that you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-11 23:55:45] |
I see, I did not realize that additional columns and data is created by studies. Thanks. |
