Date/Time: Fri, 03 May 2024 19:04:58 +0000
Directional Movement Index
View Count: 541
[2018-09-10 15:49:13] |
infpz - Posts: 826 |
DMI seems to not update until bar close. Any reason?
[2018-09-10 16:37:00] |
No, it is continuously calculated and updates. Make sure the chart is scrolled to the end and that there is no displacement being used.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-10 16:37:29
