Date/Time: Sat, 04 May 2024 02:24:59 +0000
Symbol alert right-click option missing when pointer/cross over drawing tool
View Count: 1105
[2018-09-10 07:29:32] |
JanS - Posts: 46 |
Can you add the "Add Symbol Alert" option to the right-click menu even when the mouse is directly over a drawing? I use a laptop (small screen) showing six charts at once. I often want to set a symbol alert on a price where there is a fibonacci line. At the moment, I cannot do so because I get a different right-click menu that does not show the symbol alert option but the options specific to the drawing tool selected. Instead, I have to set the alert somewhere else in the chart, then change the price manually. |
[2018-10-29 21:13:01] |
anpy - Posts: 35 |
Same request. With a few fib retracement lines on the chart it gets impossible to add alerts through the chart shortcut menu.
Date Time Of Last Edit: 2018-10-29 21:14:44
[2018-10-31 18:11:37] |
We will see what we can do in this regard. For now we recommend that you just simply use another chart without Chart Drawings and set Symbol Alerts that way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 18:13:00
[2022-08-16 12:56:38] |
Sierra_Chart Engineering - Posts: 14207 |
This will be supported in the next release.
