Date/Time: Mon, 29 Apr 2024 01:41:38 +0000
Toolbar 8 changed again. Can we have more control?
View Count: 602
[2018-09-09 12:34:13] |
User92573 - Posts: 483 |
Dear Support I see on updating my version that the toolbar has changed again in as much as the 'fixed' button size has been increased so my earlier layout to which I have become accustomed no longer fits. Can we have: Control of fixed button size. The return of underlying font colour which was available in v.1 of toolbar 8 which I contributed to. This allowed you identify the text colour immediately. Background colour does not replace this. Replay start/pause added as a button to toolbar 8 as it is easy to stop replay by mistake. -------------------------------------------------------------------------------------------------------- One further very useful addition found on many platforms is the ability on tools such as retracements etc. to either 'Keep Me' which automatically hides all other levels for that selected retracement set; and select >> hide + ctrl or similar whereby all subsequent selections for that specific set while ctrl is held down are hidden on select/click. This saves continually reselecting the set and hiding everyone not required individually. Opening and editing the tool itself is also very slow. --------------------------------------------------------------------------------------------------------- Apologies as I've had a few queries lately and realise you a busy with major tasks. Many thanks |
[2018-09-09 20:20:11] |
You can change the font size of the control bar buttons: Control Bar: Control Bar Buttons Size and Text Size This has always been fully adjustable. The return of underlying font colour which was available in v.1 of toolbar 8 which I contributed to.
We thought we had implemented this for you. We will need to check on this again.Replay start/pause added as a button to toolbar 8 as it is easy to stop replay by mistake.
You can add these. They are on the Chart menu and can be easily added just in the same way you add any other control bar button.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-09 20:20:43
[2018-09-11 08:59:48] |
Brilliant! Brilliant! Thank you! |
