Date/Time: Sun, 28 Apr 2024 23:42:36 +0000
v1798, Right Click on Chart to Open Shortcut Menu Stopped Working
View Count: 1069
[2018-09-06 15:46:49] |
User379468 - Posts: 508 |
After upgrade, right click on chart doesn't do anything, how can I get it back to open chart shortcut menu? Going back to v1784 fixes it. Date Time Of Last Edit: 2018-09-06 16:19:09
[2018-09-06 16:29:14] |
Make sure that Global Settings >> Tool Settings >> Right Click Exits Current Drawing Tool is unchecked. We see how what you describe is the case when that option is enabled and we are going to resolve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-06 17:29:03] |
Right click to exit current drawing tool used to work previously. How can I get that back also?
[2018-09-07 06:19:00] |
Acro - Posts: 436 |
I'm using 1799 prerelease and not sure that right click to exit current drawing tool is working as intended. Eg if I use the custom text drawing tool via a control bar button set to repeat the same text again, then when I right click yes it does exit but does not get me back to the crosshair. Instead it gets me first to a cursor and then a standard text tool. Not sure why this happens or what is going on. |
[2018-09-07 06:44:16] |
We have not yet done a new release with the changes.
[2018-09-10 21:32:02] |
in 1803, right click to exit drawing tool now works, and chart shortcut menu now works, but: Right click doesn't delete a drawing until it's repeated twice. And it doesn't go back to the configured 'After Single Tool Use Change to:'. |
[2018-09-11 03:09:32] |
This will be improved upon and accomplished in the next release.
