Date/Time: Mon, 29 Apr 2024 16:21:12 +0000
New Numbers Bars Calculated Values 2 study
View Count: 2201
[2018-09-06 05:34:20] |
User99934 - Posts: 227 |
Pullback column does not work when set to yes.
[2018-09-06 16:06:42] |
John - SC Support - Posts: 31162 |
The Pullback Column is working properly, but we did not include this particular data for the pullback as we did not think it would be relevant given the changing nature of the pullback. We have gone ahead and added the support for the Pullback Column for the current items in the Numbers Bars Calculated Values 2 study. This will be in the next release - 1800. When available, you can update to that release following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-06 16:36:41] |
It would be far more helpful to allow all studies to universally access the pullback column.
[2018-09-06 16:53:38] |
It depends on whether the data is available in the Pullback Column. Not all the data is readily available and therefore can not be displayed.
[2018-09-06 17:25:40] |
It seems the following is available?: Ask vol Bid vol difference, volume, trades, Bid Vol x Ask Vol, Dominant side volume percent, price, ask vol bid vol difference diagonal. Perhaps there could be an option in the number bars to allow access?
[2018-09-06 18:01:39] |
You have me confused. Yes, there are a number of items in the Numbers Bars Calculated Values study that will display data in the Pullback Column. Additionally, there are specific items that can be displayed in the Numbers Bars pullback column. What information are you looking for that is not currently present? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-10 07:44:46] |
Its more that I would like to reference with alerts, studies, etc. in that bar space with the available data. Treat it like a regular bar - as much as possible with the data that is available. At present time, I would like ask/bid volume difference bars, volume, price.
[2018-09-10 13:35:05] |
It is possible to access the data in the Pullback Column by using the identifier of [1] in the Alerts/Studies. Refer to the following: Study/Chart Alerts And Scanning: Referencing Data Beyond the Last Bar in the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-10 13:46:32] |
I am not clear where to put the [1] identifier for ask/bid volume difference bars.
[2018-09-10 14:07:12] |
Sorry, the [1] will only work when you are using the Numbers Bars or Numbers Bars Calculated Values. It is not available with the Ask/Bid Difference Bars. Therefore, if you want to see the Ask/Bid Volume Difference in the Pullback column, you need to use the Numbers Bars Calculated Values study and then you can reference the Pullback for the first Subgraph (Ask Volume Bid Volume Difference) as IDx.SG1[1], which will give you the data in the Pullback for the Ask Volume Bid Volume Difference (change the x to the ID of the Numbers Bars Calculated Values study). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-10 14:11:32] |
Thank you.
