Date/Time: Sat, 04 May 2024 03:12:02 +0000
ab=cd
View Count: 1430
[2018-09-03 23:36:14] |
tbillm - Posts: 8 |
Is it possible to get just a simple draw tool addendum to draw this simple formation and the ability to add the harmonics we would like. Its such a nice tool to pull up and use to check targets etc ty |
[2018-09-04 02:29:07] |
We really do not know what you are describing. We need a more clear explanation. A drawing as an image file would be best.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-04 02:29:21
[2018-09-04 19:58:39] |
tbillm - Posts: 8 |
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwiRt9aUkKLdAhUO0awKHewCBXwQjRx6BAgBEAU&url=http%3A%2F%2Fbonniehill.net%2Fpages.aux%2Fensign%2Ftt%2Ftt77.htm&psig=AOvVaw1WHRrjA5WnIQsIWrm853w0&ust=1536177188277434 Sir please scroll down to Formations Draw Tool This pattern recurs continually and it would be nice to see its precise extension prices immediately instead of drawing fibs on the charts. Ideally the ab leg equals the cd leg. Many call it a measured move. But there is no way to quickly measure the possible moves in Sierra. Thankyou for your time tbillm |
[2018-09-11 23:42:48] |
tbillm - Posts: 8 |
Ox Hi, I noticed that you were trying at one time to get the TTM superscalper indicator for Sierra from another port. I am also but have no luck. Did you ever get it ????????? thankxs billm |
[2018-09-12 14:09:48] |
John - SC Support - Posts: 31362 |
With regards to post #3, we will look into adding this drawing tool. It will take some time before we can get to it, but we will post back here when it is done. With regards to post #4, this is not available as a standard study within Sierra Chart. It does appear to be available for Sierra Chart through TTM. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-21 23:21:57] |
User106601 - Posts: 17 |
is there any progress on this simple but very useful fib tool????? thankyou for your time, billm |
[2019-04-22 14:33:18] |
We have not been able to get to this yet. It is something we want to do, but we cannot say when exactly we will have the time to get it done.
[2020-09-09 03:26:34] |
vish100 - Posts: 111 |
Is this tool available now? Really needed
[2020-09-09 13:13:16] |
No, we have not been able to get to this drawing tool. It is still on our list but we cannot say if/when we will get to it.
[2020-09-10 02:11:50] |
I am currently using Arrow or reward risk as a workaround but a measured move tool is such a basic trading tool that I am surprised you don't have it. It will be great if you can prioritize this please. It's simply drawing three points ABC where AB = BC and you can extend it to ABCD where AB=BC=CD and so on.. |
[2022-08-18 13:52:51] |
User105544 - Posts: 4 |
Any news on this. Really need this tool.
