Date/Time: Sun, 19 May 2024 06:58:39 +0000
printing/displaying difference between high and low per candle
View Count: 608
[2018-09-03 23:34:12] |
User525733 - Posts: 126 |
Hi, I would like to print (on chart header preferably OR in "compact tool values window") the difference between high and low for the candle over which the mouse is currently on. I am aware of the "bar difference" study.....displaying the high/low difference in a separate graph is not as practical as reading a number. thanks |
[2018-09-04 02:28:17] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=56&Name=Bar_Difference#DisplayingBarDifferenceInToolValuesWindowOnly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
