Date/Time: Mon, 13 May 2024 16:46:54 +0000
[Programming Help] - REQ:Double Stochastic code
View Count: 1079
[2018-09-02 10:35:04] |
franmadrid - Posts: 24 |
Hi guys, I am looking for a double stochastic code. Exactly I am working in Ninja and Multichart and I want to move my double stochastic to Sierra. But in Sierra the D.Stochastic is very diferent , meaby the calculation is diferent. Anyone can help to me get DS from Ninja or MC to Sierra. ?? I leave you a snapshot to compare the 3 software. (the snapshot have 3diferent period 5,18 and 70 over ema75 in MC and ninja . In Sierra I posted only the 18 (blueone)) The MC (easy language) calculation is this: [LegacyColorValue = true]; {_DStoc: Double Stochastic} Inputs: DStLen(NumericSimple) ; Vars: Num(0), Denom(0), Ratio(0), PctK(0), DNum(0), DDenom(0), DRatio(0), DPctK(0) ; {Stoc} Num=C-_Lst(L,DStLen); Denom=_Hst(H,DStLen)-_Lst(L,DStLen); Ratio=IFF(Denom>0,(Num/Denom)*100,Ratio[1]); PctK=IFF(CurrentBar=1,Ratio,PctK[1]+(.5*(Ratio-PctK[1]))); {DStoc} DNum=PctK-_Lst(PctK,DStLen); DDenom=_Hst(PctK,DStLen)-_Lst(PctK,DStLen); DRatio=IFF(DDenom>0,(DNum/DDenom)*100,DRatio[1]); DPctK=IFF(CurrentBar=1,DRatio,DPctK[1]+(.5*(DRatio-DPctK[1]))); _DStoc=DPctK; |
sierra_double_stochastic_vs_ninja_MC.jpg / V - Attached On 2018-09-02 10:33:12 UTC - Size: 1.38 MB - 317 views |
[2018-09-03 03:42:46] |
We will look this over.
[2018-09-03 09:52:46] |
thanks I leave you a template to use in Ninja trade with all setup.
Date Time Of Last Edit: 2018-09-04 04:32:37
[2018-09-04 04:32:21] |
We do not need that. We are deleting the file.
[2018-09-24 22:15:46] |
This is what we determined: The formulas that the user has provided in EasyLanguage are just flat-out wrong. Sierra Chart is using the correct ones. We can add the study, but there would be a cost associated with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
