Date/Time: Sat, 18 May 2024 14:10:15 +0000
Daily Chart Dual Session
View Count: 694
[2018-08-31 13:57:10] |
User750920 - Posts: 274 |
Is it possible to display the entire day (RTH and Evening Session) as daily bars but not as one bar but have the Day Session (RTH) and Evening Session represented as 2 bars. Currently I have the day periodicity set as 1-0-0 so as to get all the VbP profile details and trades. I would like to have a dual session for daily bars like the TPO profiles are able.
Date Time Of Last Edit: 2018-08-31 20:49:03
[2018-08-31 21:15:03] |
I think I figured it out - let me know if you can if the following is the best most efficient way. Set Chart setting to include evening and then set period to 0-860-0 |
[2018-08-31 21:25:29] |
We do not have any other suggestion. Our answer was going to be that what you want to do is not supported. But if you have figured out a way to do it, that is fine. We would have to think about why that actually works.
[2018-08-31 22:07:50] |
Well since it does I am content. And please don't change it :) The program I am trying to migrate from to SC does it so I remembered and thought I would try it here. Also I think it works since the bar size of the night session is 860 minutes for this chart and since the entire trade day (night + RTH) is included in one day then the remaining minutes are allocated to the RTH portion of the day. And then the next day starts it just repeats itself. |
