Date/Time: Sun, 19 May 2024 05:06:34 +0000
Trading System Based on Alert Condition - Adding to position
View Count: 1129
[2018-08-30 19:55:33] |
User87744 - Posts: 22 |
I notice that when Trading System Based on Alert Condition enters a trade, it will ignore subsequent entry signals until the trade is closed. Is there a setting that I can change to enable the system to add to an open position? And if not, is there a work around? Edit: I'll answer my own question. No the study does not support multiple entries in same direction. Any chance you can add support for this in the next version? It'd be very useful. Separate question: Are there any issues with running, say, two Trading System Based on Alert Condition studies concurrently on two charts trading the same symbol? Does the max position allowed in this situation apply to the 'global' position or just the position entered by the specific Trading System Based on Alert Condition study? Date Time Of Last Edit: 2018-08-30 20:09:32
[2018-09-03 22:28:51] |
Edit: I'll answer my own question. No the study does not support multiple entries in same direction. Any chance you can add support for this in the next version? It'd be very useful. Yes we can do this but use the option with caution.Separate question: Are there any issues with running, say, two Trading System Based on Alert Condition studies concurrently on two charts trading the same symbol? Does the max position allowed in this situation apply to the 'global' position or just the position entered by the specific Trading System Based on Alert Condition study? This is explained here:Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-04 08:12:16] |
nioko54130 - Posts: 108 |
Yes we can do this but use the option with caution. Is adding this input (Allow multiple entry in same direction" into the acsil cpp file is enough to get this function available? i have done it on the acsil interface, but i'm not sur it's correctly activated. thank's |
zzzzzzzzzzzzzzzzzzzzzzzzzzz.PNG / V - Attached On 2018-09-04 08:10:55 UTC - Size: 374.91 KB - 260 views |
[2018-09-04 09:22:24] |
Is adding this input (Allow multiple entry in same direction" into the acsil cpp file is enough to get this function available? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-04 14:24:03] |
this is what i'v done, and the feature is correctly displayed into my input list as you can see on the screen shot in attached file! therefore, when i activated this input and set it to yes, i see that i have some rejected orders because some orders are already existing. I have noticed the same issue with the "allow working orders" input that i have also already added into the input list. Maybe i have missed somethings, thank's for your help |
allow multiple entrey in same direction enabled.PNG / V - Attached On 2018-09-04 14:13:06 UTC - Size: 256.11 KB - 373 views |
