Date/Time: Sun, 19 May 2024 02:57:46 +0000
clarification on Updating Existing Installation of SC with files from another installation
View Count: 542
[2018-08-30 15:29:29] |
User525733 - Posts: 126 |
Hi, under the section "Updating Existing Installation of Sierra Chart with Files and Settings from Another Installation" found in the link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation we read the following: "2. Copy all of the files in this Sierra Chart folder and the following subfolders: ACS_Source, AlertSounds, Data, Graphics....etc" please find attached a screen shot of the files i find under my SOURCE SC installation folder. Should i copy ALL these files in addition to the mentioned folders? I do wish to move all my chartbooks, settings and everything to a new SC installation on a different machine. thanks |
[2018-08-30 17:59:39] |
You really can copy everything. Follow these specific instructions: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
