Date/Time: Sat, 18 May 2024 10:08:47 +0000
[Programming Help] - Better Divergence study creation question
View Count: 795
[2018-08-29 08:50:34] |
User7817001 - Posts: 96 |
In an attempt to create a better divergence study not using spreadsheet. I am in need of a method using existing studies to compare the prices at two different alert instances. Alerts are done, manipulating them, not a problem. Where I am stuck is capturing and comparing the prices when the alerts are triggered. Thanks Mark |
[2018-08-29 18:15:28] |
You would need to use the Color Bar Based on Alert Condition study and reference the results from that. Refer to: Color Bar Based on Alert Condition ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
