Date/Time: Tue, 28 May 2024 02:37:38 +0000
Intraday chart won't go back past 2018-07-10
View Count: 566
[2018-08-28 20:56:16] |
User828417 - Posts: 32 |
I have an intraday chart for USD.CAD-IDEALPRO. The date range in file is 2018-07-10 to 2018-08-28. Days to load = 1000 I'm trying to get a 4 hr chart that goes back to 2017-07-10, but any date I enter prior to that date, gets reset to 2018-07-10. |
[2018-08-29 00:55:35] |
Make sure you are using the correct Forex symbol because that one is incomplete. You can see them in File >> Find Symbol. Follow the instructions here to access more historical data: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
