Date/Time: Sun, 19 May 2024 12:15:48 +0000
EPIQ always showing as current order size
View Count: 622
[2018-08-28 16:12:22] |
chili - Posts: 14 |
I have estimated position in queue tracking enabled along with Display Additional Order Information per the documentation, however the estimated position is always initially displaying as the order quantity, and then goes increasingly negative from there as orders hit the bid/ask. I have bid and ask size data at the price level of the order entry as well, so not sure what could be causing the issue?
[2018-08-29 00:24:15] |
We see you are using CTS. This could be something which is CTS specific. We will have to look into this.
