Date/Time: Sat, 12 Jul 2025 07:13:40 +0000
Pre-setting Stop to move
View Count: 1449
[2013-10-22 13:51:09] |
37010589 - Posts: 2 |
Hello!! Is there any way I can pre-set the Stop (all) to move up one full point automatically, once the 1st Profit Target gets filled (taken out)? |
[2013-10-23 03:51:20] |
Yes. This can be done by using the Move to Breakeven For Stops settings for Attached Orders. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#MoveBreakevenForStop You can configure it to move the stop anywhere relative to fill price of the parent. So by doing the calculations you can make this 1 full point relative to the stop order price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-23 14:20:33] |
Thank you!!
