Date/Time: Sat, 18 May 2024 10:42:06 +0000
Point and Figure x and o's not appearing
View Count: 673
[2018-08-28 00:06:38] |
User347150 - Posts: 29 |
Hello, The point and figure studies X and O's columns are not appearing on my chart. Only the "Line on Close" is appears on the chart when I set the subgraph to "Line on Close". When I set the subgraph to "Point and Figure X-O Columns" nothing at all appears on the chart. I think that the input setting are correct as per instructions. Please help me if you can. Sincerely, Everett |
[2018-08-28 19:03:44] |
You should use the Bar Period Type type of Point and Figure rather than the older study. Refer to the following documentation: Chart Settings: Point and Figure Bar (Intraday Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-29 03:20:00] |
Thank you. I notice that the volume study on the bottom of the chart shows consecutive red (down) bars and consecutive green (up) bars, while the point and figure chart shows only alternative (down) o's and (up) x's columns. Please explain why the volume study on the bottom of the chart does not show alternating red and green bars to correspond to the alternating o's and x's columns in the point and figure chart. Thank you.
[2018-08-30 08:40:44] |
We see why this is the case and this will be solved in the next release. It has to do with separate arrays used for the point and figure high and low values.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 08:41:25
