Date/Time: Sun, 19 May 2024 05:07:30 +0000
Advance Decline line...
View Count: 1225
[2018-08-27 15:27:05] |
User629089 - Posts: 93 |
Hi, I'm trying to set up an A/D line for the NYSE. I'm using NISS-NYSE symbol for the chart. Adding the Advance Decline Line study would be fine but I'd like the study to reset on each RTH session. That leads me to the Cumulative Sum of Study study. The question is on the inputs, "Study and Subgraph to Reference". Box 1 almost has to be the "Main Price Graph" and not the "Cumulative Sum of Study", correct? I don't know what the second box should be set at. I've tried all options (Open through Ask Volume) and I'm unsure what should be used. Is this correct? I don't think the Advance Decline Line study should be included here but maybe I'm wrong. Any ideas? Thanks... |
[2018-08-27 17:25:39] |
You do need to use Cumulative Sum of Study. Box 1 almost has to be the "Main Price Graph" and not the "Cumulative Sum of Study", correct? Yes this is correct.The second list box needs to be set to "Last". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-27 17:26:45
