Date/Time: Sun, 19 May 2024 05:43:24 +0000
Restarting Sierra resets my Numbers Bar Settings and Additional Symbols Chart
View Count: 583
[2018-08-27 14:59:28] |
jaxscott1 - Posts: 24 |
Weird but perhaps? Everytime I restart my Sierra Charts it resets the Numbers Bar - Column 1 Percent Compare Thresholds settings back to default 0.25, 0.5, 0.75. (I'm trying to keep it at 4,4,4). Also, I have a correlation chart with four equities futures and on restart it takes the symbols settings out of the symbol field in ID1 and leaves it blank. Weird... and annoying to have to reset every time. |
NumbersBar.png / V - Attached On 2018-08-27 14:59:05 UTC - Size: 669.41 KB - 260 views Add Symbols.png / V - Attached On 2018-08-27 14:59:14 UTC - Size: 423.38 KB - 255 views |
[2018-08-27 16:13:31] |
This has been solved. You will need to update to prerelease 1793: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-27 16:15:01
