Date/Time: Sun, 19 May 2024 06:11:18 +0000
CQG/SC Trial
View Count: 1033
[2018-08-27 10:39:28] |
User883370 - Posts: 6 |
Hello, I've got a password from cqg, but if I enter that at cqg-api then the hint comes that it's unknown. I receive data via "SC Data - all services", but there is no real-time data. |
[2018-08-27 16:47:47] |
Follow through the step-by-step instructions here to use CQG: CQG Trading Platform Service: Setup Instructions If there is a connection problem, you will need to have your broker help you with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-27 16:48:10
