Date/Time: Sun, 19 May 2024 05:23:57 +0000
Cannot cancel orders
View Count: 2030
[2018-08-27 08:26:36] |
User798235 - Posts: 10 |
Hi! I use gain futures and while i can send and modify an order, when i try to cancel them in the DOM they only say, cancellation pending, waits for a while and then it just says open in the order window. cancel through gains plattform works well. i cannot find any related messages |
[2018-08-27 09:05:07] |
User93489 - Posts: 1 |
Hi, Exactly same problem for me occurred today. Canceling orders was working fine last week. |
[2018-08-27 09:10:08] |
Clearly the Gain Capital FIX server is having a problem. We will need to contact them about this. Update: We have now contacted Gain Capital about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-27 09:16:11
[2018-08-27 16:10:36] |
Bedhog - Posts: 168 |
Yes, I got hit by this today. Broker pushed back to me and said it was a problem with SC... that an update was needed. When orders hang on the server side and SC cannot manage them, is there a better number to call for information than the broker? Are we allowed to call a GAIN desk directly ? Date Time Of Last Edit: 2018-08-27 16:14:52
[2018-08-27 16:47:01] |
This is from Gain Capital about this in regards to their FIX server: A fix will be released at 5pm ET and will be ready by 6pm ET open.
