Date/Time: Sat, 04 May 2024 08:54:54 +0000
Ver1785. Chart Trade with keybord shortcut bug.
View Count: 726
[2018-08-24 12:55:34] |
YK - Posts: 33 |
"Trade Volume Triggered Stop" with keybord shortcut command "Buy Send Attached Orders - Position" does not work. "Sell Send Attached Orders - Position" with "Trade Volume Triggered Stop" also does not work. Date Time Of Last Edit: 2018-08-24 12:56:47
[2018-08-24 19:54:36] |
Specifically what do you mean by "does not work"?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-24 19:54:43
[2018-08-24 20:25:14] |
YK - Posts: 33 |
Does not execute the order. If trade volume exceed the specified volume then nothing happen. If price cross over the stop price then nothing happen. This issue only occer #1. |
[2018-08-31 18:30:46] |
Okay we will test this.
[2018-09-25 18:48:00] |
Let us know if you still see a problem with this in the current version of Sierra Chart. Which is now 1809.
[2018-09-26 01:47:18] |
YK - Posts: 33 |
"Send Attuched Order By Position" with "Volume Triggered Stop" does not work. This is work as "Stop". When the price hit the "Volume Triggered Stop" price, "Volume Triggered Stop" immediately execute. There is no trade volume count. |
[2018-09-28 06:02:58] |
We have gone into this issue in depth and we understand the reason for the problem. We are working on a solution now.
