Date/Time: Sat, 12 Jul 2025 00:44:18 +0000
Trailing Stops in Sierra.
View Count: 2251
[2013-10-21 23:43:20] |
User90051 - Posts: 3 |
Does Sierra have fixed and dynamic trailing stops for forex? For example. One stop will move tick for tick with the market after stop has moved to breakeven and the other will keep locking in say 10 pips at a time. SO market has to move 10 pips to move stop up 10 pips. In dynamic, the market moves a pip, the stop moves a pip. Thank you. |
[2013-10-22 01:38:14] |
Yes. This is all supported. Refer to this page for all of the order types: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html And to this section for the Move to Breakeven for Stop functionality for Attached Orders: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#MoveBreakevenForStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-22 01:39:41
[2013-10-22 19:45:14] |
Could you tell me which one is which. Which one is a fixed amount and which one moves tic for tic. Will make it easy as there are quite a few and a bit confusing to me. Thank you. |
[2013-10-22 21:03:58] |
The trailing stops that have "Step" in their name, step in amounts greater than 1 Tick. The other trailing stops move tick by tick.
[2013-10-23 01:10:12] |
Thank you. I am still a little confused. Which two specifically do I use when I want to move stop to breakeven and then trail it pip for pip or in steps. Thanks. |
[2013-10-23 12:37:41] |
Here are the links to the particular stops you need to use: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#TriggeredTrailingStop http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#TriggeredStepTrailingStop To make a Stop Attached order move to breakeven, follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#MoveBreakevenForStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-23 12:38:57
