Date/Time: Tue, 29 Sep 2026 12:29:51 +0000
DLL with custom study can't be opened
View Count: 3030
[2013-10-21 19:32:28]
RobertKoperczak - Posts: 2
I got from my friend some ".dll" file with custom study. While trying to open it (Analysis->Studies->AddCustomStudy)in the Message Log box appears error "Error loading C:\SierraChart\SierraChartTransActMA\Data\WillyplCustomStudy.dll. Windows error code 126: Nie można odnaleźć określonego modułu.
My ".DLL" file is saved in proper folder (SierraChartTransActMA\Data).
Attached DLL that makes problem.
Please help me to solve this problem.
Please contact skype : robert.koperczak or +48668158500 if direct conversation will be necessary
attachmentWillyplCustomStudy.dll - Attached On 2013-10-21 19:30:53 UTC - Size: 41.5 KB - 941 views
[2013-10-21 19:44:40]
This is probably caused by anti-malware/Antivirus/security software running on your system. Try disabling the security software.
Another thing is that if you right-click on the file in Windows Explorer and select Properties, somewhere within the settings, there will be a button to allow/unblock the file because it may have been blocked because it was obtained from another system.
[2013-10-21 21:16:19]
Problem occurs even after deactivating antivirus software (avast!).
All properties of the ".dll" file are the same as other "dll" which works.
I have no idea what's up. Maybe someone of support crew will connect my computer in remote mode ?
[2013-10-21 21:46:01]
This is not something we provide remote assistance for. This is an issue which is system specific or related to the particular DLL. It is not something we have direct control over.
We recommend that they provide you the actual study source code and you compile it on your system following these instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html
In this kind of case, this is really the only practical and efficient solution.
Date Time Of Last Edit: 2013-10-21 21:46:26
[2013-10-24 14:01:21]
market logik - Posts: 6
I want to report a solution worked for me.
I had same error:
In my owwn computer DLL's created with Microsoft Visual C++ installed worked well, but when exporting just Custom.DLL to other didn't work and had same error.
Try to add to header below:
#include "sierrachart.h"
(Had this one already)
#include "scstudyfunctions.h"
(I missed this one)
I did include second header line, re-built and works fine in all computers I share DLL's now.
Hope this helps someone.
Happy trading
[2013-10-24 17:32:20]
We see no reason why including that header file would make any difference regarding error 126: "The specified module could not be found. "
[2013-10-24 17:40:11]
Me neither, but my case was that in computer with Visual Installed worked fine.
I changed computer and my own Custom DLL's gave me that error.
Also in a third computer.
Added that second line on header and now works
That's why I wanted to mention in case someone helps.
Thx,
