Date/Time: Thu, 09 May 2024 20:34:44 +0000
Market Orders Executed Vs Limit Orders
View Count: 1025
[2018-08-21 16:47:34] |
User226793 - Posts: 160 |
Hey Guys, When i place an order through the trade window, it places a market order rather than a limit; what settings do i need to change to make sure the order is executed correctly?
[2018-08-21 18:24:47] |
How exactly are you submitting the order. What is the name of the button you are using on the Trade Window?
[2018-08-21 18:28:09] |
I place the orders from the chart
[2018-08-21 18:32:26] |
We need 100% precise details on exactly how you are submitting the order. This is not descriptive for us.
[2018-08-21 18:59:46] |
I click on the "Trading Chart Dom" to create a limit order.. However It executes as a market order
[2018-08-21 20:23:29] |
It sounds as though Stop orders are being used. You need to configure the chart DOM order types as you require as explained at step 6 here: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
