Date/Time: Fri, 10 May 2024 12:52:21 +0000
Difference in feeds
View Count: 555
[2018-08-21 08:31:14] |
Stuart Murray - Posts: 1 |
Good morning, could you please tell me the difference between the Eurex and the Eurex Professional feed. Many thanks |
[2018-08-21 08:41:22] |
There is no difference. Only that if you are considered professional by the EUREX you have to pay more. This is all.
