Date/Time: Sun, 19 May 2024 09:16:35 +0000
Tick, Intraday (1min) and Daily Historical Data
View Count: 1290
[2018-08-20 20:58:50] |
User750920 - Posts: 274 |
Hi, just looking for clarification. I am possibly looking to come over to Sierra form IRT With IRT I use realtime live data from my brokerage account which is supported by Sierra. I then get tick, intraday and daily historical data which backfills my charts each time I start the program (or if I need to backfill during the day for any reason) from DTNMA provided through IRT. Does Sierra work in this manner and if so what is the cost of the historical data. It seems this is provided (looking for confirmation) but not sure on the cost. If provided how much tick, intraday and daily can I download and save in the Sierra database. Thanks for the time Marc |
[2018-08-20 21:09:12] |
Really the best thing is that you use the Sierra Chart Exchange Data Feed for both the historical and real-time data: Sierra Chart Exchange Data Feed This data feed has a reasonable price. The details of how much data is available is on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-20 21:10:09
[2018-08-20 21:15:41] |
I saw that as an option - but I am looking to see if I can reduce my overall costs. If I do that my costs remain basically the same.
[2018-08-20 22:12:08] |
Not sure what Trading service you want to use but in most cases the historical data is provided by Sierra Chart and will be tick by tick if you are using the Advanced Service Package (5).
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-20 22:16:02
[2018-09-03 15:35:29] |
An additional question to append this thread. Still working on migrating to Sierra and setting things up. I will be using GAIN feed and Sierra historical (tick, intraday etc data). When I start Sierra it seems to be downloading data every time. Does Sierra Chart store the downloaded data on my hard drive in a database and then every time I close and restart Sierra it just appends (fills) the current data to present or does it redownload it all every time. |
[2018-09-03 20:36:27] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/ChartDataFiles.html#IntraDayUpdated Only the missing data is downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-03 21:48:15] |
A little confused. Should I add symbols to the Update list if I have a live feed from a broker (GAIN)? Also then the data that has been downloaded is stored on my Computer? And when I start Sierra and see the percentage counting up it is building the chart - that is not the data downloaded. |
[2018-09-03 22:00:46] |
There is nothing more you need to do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-03 22:02:59
[2018-09-04 03:53:03] |
And when I start Sierra and see the percentage counting up it is building the chart - that is not the data downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
