Date/Time: Sun, 12 May 2024 20:06:05 +0000
ETH Volume on Friday not merging...
View Count: 593
[2018-08-19 23:32:25] |
User629089 - Posts: 93 |
Hi, I've set up a chart that shows the volume from right after the RTH close in CL @ 1:30 CST on any day to the start of the next RTH session @ 7:59:59 the next morning. It's works perfect except for the Friday 1:30 - 4:00 doesn't merge with the Sunday open @ 5:00 and after. This is of course due to the weekend. Is there a way to merge that data from Friday after the RTH close with the Sunday data? If that's not possible, would there be a way to eliminate that 1:30 - 4:00 Friday data from the calculation? That of course wouldn't be the best but definitely better that the way it is now. It's like there's a 6th day in the calculation/chart that shouldn't be there. Thanks... |
[2018-08-20 01:01:42] |
You are going to want to set the chart to not load the weekend data:http://www.sierrachart.com/index.php?page=doc/SessionTimes.php#LoadWeekendDataSetting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
