Date/Time: Sun, 28 Apr 2024 15:50:38 +0000
Trading: Position - How do I get my current Average Price?
View Count: 1624
[2018-08-18 21:03:42] |
CRX - Posts: 7 |
I have looked everywhere endlessly to try to obtain information on how to get my position data to utilize by referencing in alert conditions. The closest I have gotten is the study "Trading: Position," which contains the "Pos Qty" information, but does not contain the "@Price" data, or otherwise known as the Average Position Price. I would like to be able to use this in an alert condition as I can with the position quantity. I have 2 days left on my trial before deciding upon this software and this appears to be my last hurdle. Thanks guys! |
[2018-08-20 01:06:52] |
CRX - Posts: 7 |
I have since signed up for a subscription. This would be very helpful to know. Thank you.
[2018-08-20 01:25:04] |
You can only access this data by using the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading There is a cell where this value is outputted to on the Sheet. Or by using ACSIL: Automated Trading From an Advanced Custom Study You cannot do this with simple alerts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-20 16:12:49] |
CRX - Posts: 7 |
Thank you, I do not want to use the Spreadsheet System. Could you kindly point me in the direction of the source code for the study "Trading: Position" (image of what I am referring to attached)? I have searched through the files and have only been able to come up with the source for the other studies, but can't seem to find this one. When I can finally locate this one, I should be able to have everything I need. Thanks so much for your help in advance. |
2018-08-20_11-43-49.jpg / V - Attached On 2018-08-20 16:12:06 UTC - Size: 62.05 KB - 265 views Attachment Deleted. |
[2018-08-20 19:39:26] |
The source code for it is not available: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available If you want to use ACSIL to access this data, then use this function: Automated Trading From an Advanced Custom Study: Getting Trade Position Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-20 19:39:59
[2018-08-20 19:56:07] |
CRX - Posts: 7 |
Yeah, I don't know how to do that. I was going to replicate the study by using the source as a template. Can anyone help me out? |
[2018-08-20 20:18:48] |
We will add a study to do what you want. This will be out in a few days.
[2018-08-20 20:32:56] |
CRX - Posts: 7 |
Ah excellent! Thank you so much!
[2019-01-11 15:22:35] |
User993113 - Posts: 71 |
We will add a study to do what you want. This will be out in a few days. I was looking for the same studyI only need the TEXT showing me what is my average price. How is called this study? |
[2019-01-11 22:39:15] |
The study is called "Trading: Position Average Price" but we can see that it was never listed. This will be in the next release.
