Date/Time: Mon, 13 May 2024 20:35:34 +0000
Build 1789 screws up position and order lines in the chart
View Count: 1798
[2018-08-17 13:59:35] |
Cavalry3162 - Posts: 523 |
color settings are ignored, see screenshot. did not happen with 1788, i updated and it was like this. |
2018-08-17_09-55-09.png / V - Attached On 2018-08-17 13:58:43 UTC - Size: 19.34 KB - 350 views |
[2018-08-17 15:16:18] |
nioko54130 - Posts: 108 |
hello dear support ! i have also the same problem with the 1789! I am forced to change the scale range of my main graph region, from "automatic" to "constant range". If i do not, the chart is broken. but if i do it, my different chart element are not set on the same scale. Maybe this issue is coming from the fact that i have few different element on this same region 1 ? I got the dom heatmap, then the price action and different cumulative delta line all set on these region 1. In the previous version (1778) i was able to put the scale in automatic without any problem (in order to get all of my line value, and heatmap set on the same scale) Thank's for your precious help |
[2018-08-17 15:28:53] |
To illustrate the situation : If i change nothing on the scale range it's showing to me a chart like that (lightly broken) |
broken chart after update to 1789.PNG / V - Attached On 2018-08-17 15:28:38 UTC - Size: 136.24 KB - 397 views Attachment Deleted. |
[2018-08-17 15:32:15] |
then if i change the scale range, from automatic to "constant range", it's displaying my tool better, but the different line are now not set on the same scale than the price scale. Thank's for your help |
after changing from automated scale range to constant range.PNG / V - Attached On 2018-08-17 15:32:10 UTC - Size: 246.11 KB - 1681 views |
[2018-08-17 16:01:03] |
fun fact, after sierra crashed twice (dont know why yet) the colors are back to normal... @nioko54130 may i ask you what stady you use for your "bubbles" and "hft buying text" stuff? thanks a lot! |
[2018-08-17 16:58:23] |
oh great! maybe this issue has been already resolved!? did you download the last update released? thank's for my workspace, it is the quantmap! regards |
[2018-08-17 17:10:05] |
Provide the chart you are using where you are seeing a problem, by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
