Date/Time: Mon, 13 May 2024 20:57:35 +0000
dll file
View Count: 1286
[2018-08-17 13:56:55] |
Trader&Hunter - Posts: 129 |
I have a custom dll file and mine is different on my sc than the coder. why so? what settings would I need to change?
[2018-08-17 17:16:29] |
This is really a question you need to ask the developer of this particular Custom Study.
[2018-08-17 17:25:21] |
not really. there are like 5 other people that have the same and mine is different. clearly some setting on my platform is different
[2018-08-17 17:39:20] |
Our answer remains the same even if there are 100,000 others having the same issue.
