Date/Time: Wed, 15 May 2024 10:30:43 +0000
Problems with Colour Bar Based on Alert Condition in version 1789
View Count: 707
[2018-08-17 09:19:02] |
samual sprat - Posts: 343 |
Hi, Since updating to version 1789 from 1788 the chart scaling when using Colour Bar Based on Alert Condition with draw style 'point' squashes the chart and is unreadable. I have to change the scaling for the study to 'same as region' from 'automatic' in order to fix this. I also noticed that the 'point' draw style on the chart looks like 'line' now, although the point value is set correctly in the study. Not sure if this is affecting other draw styles as i've not tested. Reverting back to 1788 has fixed the issue for me Thanks S |
[2018-08-17 09:33:21] |
There is definitively no problem here at all. The Point Draw Style displays correctly so long as you have set the Inputs appropriately: http://www.sierrachart.com/image.php?Image=1534498347962.png Refer to the documentation for this study to use alternative draw styles. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-17 09:34:01
[2018-08-17 09:45:41] |
You can still use an automatic scale. Here is the relevant documentation: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars We see no evidence of any changes affecting scaling. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-17 12:15:53] |
I'll take a look. Only way I could get the scaling to go back to the way it was in 1788 was to change all scaling in my colour bar based on alert condition studies to 'same as region'
