Date/Time: Fri, 04 Jul 2025 00:08:44 +0000
Question...
View Count: 2581
[2013-04-07 00:46:16] |
C. Notes - Posts: 130 |
Is there a way to save a group of chartbooks?
[2013-04-07 00:48:21] |
... I know we're getting kind of meta here, but would be cool if I could save a "Session" which would contain chartbooks... |
[2013-04-07 02:02:36] |
Yes. Simply use File >> Save All. You can also set a group of Chartbooks to open on start up through Global Settings >> General Settings >> Files to Open on Start Up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-07 02:02:54
[2013-04-08 22:29:11] |
Hi, Thank you this is exactly what I was looking for. Another question... If I am using multiple trading spreadsheets for the same symbol, yet only using one for the actual trading are there any negative effects to this? |
[2013-04-08 22:39:30] |
As long as the other Spreadsheets have the Disable Auto Trading cell set, you should be fine: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#DisableAutoTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-08 22:42:22] |
Ok... This is what I thought... Thanks |
