Date/Time: Mon, 20 May 2024 20:38:47 +0000
[Programming Help] - VAC container method
View Count: 802
[2018-08-16 11:36:27] |
User30743 - Posts: 364 |
hi I am trying to use the defined methods for VAP container but Visual Studio cannot compile it due to something missing (swap) in the header files .... this is what i am getting back. can you please tell me why is this happening? Date Time Of Last Edit: 2018-08-16 11:37:39
h. vac.PNG / V - Attached On 2018-08-16 11:35:42 UTC - Size: 78.28 KB - 250 views |
[2018-08-16 17:04:26] |
What version of Visual C++ are you using?
[2018-08-16 19:30:20] |
i am using version 2015.
[2018-08-16 21:16:48] |
We will make a change in the next release which we would think would resolve this. But for now in front of the swap function calls in that file put std::
