Date/Time: Mon, 20 May 2024 15:42:27 +0000
Linking Charts from different Instances
View Count: 842
[2018-08-16 08:17:25] |
User311951 - Posts: 31 |
Hi, Is it possible to link two charts from separate sub instances e.g. linking the scrolling? I know that it is possible to do this for charts within the same instance but I want to do it from different instances. Thanks, Talai |
[2018-08-16 08:28:34] |
No, this is not supported across separate instances of Sierra Chart.
