Date/Time: Mon, 20 May 2024 15:42:39 +0000
CTS Low Cost Connection Model Questions
View Count: 707
[2018-08-16 03:17:41] |
User379884 - Posts: 45 |
Hi, I have a brokerage account with AMP and the free version of SC (level 3). I am currently using CQG and server side bracket orders but am having issues whereby when the parent order fills with slippage, the server side stop and target do not adjust. Using client side brackets orders is not an option given my 260MS latency to the exchange. I have the following questions with regards to the CTS/SC combo if you could kindly answer; 1. Do I have to pay both $10 to AMP for a CTS account and $10 to activate the CTS option to SC? It is not clear... 2. I read here http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#AdjustAttachedOrdersToMaintainSameOffsetOnParentFill that when using the CTS SC combo it does in fact adjust the server side bracket order to parent fills? Just to double check... It is great that SC offers such a connection and I look forward to using this if it all checks out. I have read some really good reviews about it. Many thanks. |
[2018-08-16 05:18:02] |
1. You should only have to pay the 10 USD to us. We have pointed this out to AMP before but we do not know if it has been resolved yet. 2. Yes this is definitely correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-16 05:26:02] |
Thank you.
