Date/Time: Mon, 20 May 2024 21:28:16 +0000
Exchange Feed
View Count: 636
[2018-08-15 17:05:24] |
User600744 - Posts: 29 |
I subscribe to Sierra Chart Real Time Data Feed. What exchange do i need to subscribe to for: F.US.CLEU18 Thanks |
[2018-08-15 17:18:43] |
That is crude oil. You do have the Nymex exchange active on your account. And the correct symbol to use is CLU18. Not the one you are using. The one you are using is a CQG symbol. So you are good to go at this point. Just use the right symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
