Date/Time: Mon, 20 May 2024 14:17:15 +0000
want to use SC for trading with my AMP Futures account
View Count: 807
[2018-08-15 16:24:28] |
SuperDriveGuy - Posts: 5 |
I want to use SC for trading with my AMP account ***** instead of at FXCM. I had already contacted Amp, is there anything else, I need to to have in place with you? I am specifically interested in using the Risk Management feature, which worked very well with FXCM, where the account was READ ONLY(no new positions could be placed), except through Sierra Charts. Date Time Of Last Edit: 2018-08-15 16:37:27
[2018-08-15 19:20:11] |
No there is nothing special you need to do other than just make sure Sierra Chart is set to use your AMP trading account which can be with CQG or Rithmic in most cases. You can find the instructions for both of them here: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-15 19:40:39] |
Thanks I was able to connect fine and trade to AMP using SC. The issue is, that I was also able to connect using another platform and trade. This way I was able to bypass/override my Risk Management settings setup in Sierra Charts. With FXCM, I was only able to trade VIA Sierra Charts and no other platform even FXCM's own, which was a very effective way of implementing the Risk Management feature. Please advice. Thanks Date Time Of Last Edit: 2018-08-15 19:51:04
[2018-08-16 05:02:05] |
Not sure what your question is here.
[2018-08-16 07:37:20] |
That actually answers my question :-) Thanks
