Date/Time: Mon, 20 May 2024 14:54:08 +0000
How can I transfer the control bar from one instance to the other?
View Count: 1029
[2018-08-15 16:11:38] |
User452567 - Posts: 38 |
How can I transfer the control bar from one instance to the other? Thank you |
[2018-08-15 17:07:45] |
Refer to the "Transferring Sierra Chart Settings and Data From Existing Installation to New Installation" section here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
