Date/Time: Mon, 20 May 2024 19:50:26 +0000
Installer keeps adding shortcuts to desktop even if the checkbox is unset
View Count: 612
[2018-08-14 18:41:53] |
Cavalry3162 - Posts: 523 |
Hello SC, please fix the installer issue... see screenshot. thanks, Andreas |
2018-08-14_14-38-33.png / V - Attached On 2018-08-14 18:41:46 UTC - Size: 339.48 KB - 250 views |
[2018-08-14 19:25:06] |
This is intentional to make sure the 64-bit shortcut is installed. But at some point we can remove this.
