Date/Time: Mon, 20 May 2024 19:50:12 +0000
Different-User Accounts
View Count: 1043
[2018-08-14 13:21:38] |
Ziklag - Posts: 73 |
With FIX Credentials I could use my Sierra Chart Account to run just any number of Different-User FXCM Accounts - is this not possible under recent changes? Kindly advise on the way forward, thank you.
[2018-08-14 17:06:48] |
Yes it is possible. We will be getting back to you on this. We just needed to understand the reason for this for security reasons.
[2018-08-16 12:38:57] |
Before, I could "Disable Hedging" via "Account Settings" in myfxcm but, with recent changes Sierra Chart changes, "Account Settings" in myfxcm does not have the "Hedging Functionality." Is this 'error of omission' or is it a setting that moved from fxcm control to sierrachart - what should be the ideal way of going about this?
[2018-08-16 17:02:37] |
You will need to ask FXCM to disable the hedging functionality for the particular account.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-16 17:02:53
