Date/Time: Sat, 04 May 2024 17:56:13 +0000
Market Depth + Data Feed
View Count: 1431
[2018-08-13 20:39:04] |
User600744 - Posts: 29 |
Does Sierra Chart intend to provide market depth data for Nasdaq + NYSE stocks in the future?
[2018-08-13 23:15:36] |
We do not foresee this, at this time.
[2018-08-14 04:44:27] |
Thank you for your prompt reply. Can you recommend a data provider that provides market depth for both NYSE + Nasdaq stocks? |
[2018-08-14 18:04:56] |
You can use IQ Feed: DTN IQ Feed Data Service But this Level 2 equities data is not supported within Sierra Chart. You need to use the IQ Feed software to access it. Or you could use Interactive Brokers: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-14 18:05:36
[2021-02-11 17:00:53] |
User39772 - Posts: 311 |
Hello, is this information still valid, i.e. can I use with my current configuration (i.e. barchart equity data) the level 2 of IB in the SC trading/chart dom ? I tried e.g. AAPL-STK-ISLAND bit did not see anything. |
[2021-02-11 19:29:44] |
John - SC Support - Posts: 31362 |
It has never been possible to combine the data from two different feeds. Therefore, you would either need to use the Sierra Chart U.S. Equities data without Level 2, or you would need to use the Interactive Brokers U.S. Equities data with Level 2. If you decide that you want to use the Interactive Brokers data, then you just need to set the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds to No and the data going forward will be from Interactive Brokers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-03 17:54:38] |
There are some rumors that SC will provide a US Equity datafeed including Level II / Total View (i.e. market depth) soon. Can you comment on this and tell a bit more about your schedule ? |
