Date/Time: Mon, 20 May 2024 15:58:04 +0000
Pivot points alert
View Count: 679
[2018-08-13 07:10:43] |
GrahamL - Posts: 3 |
Hi, I wish to set up alerts to trigger when pivot point levels are reached. Within [Study Settings Pivot Points] I've gone to the [Alerts] page, ticked [Enabled, Reset Alert Condition and Alert Only Once per Bar]. Presumably I need to insert something in [Alert Condition] but would appreciate help with what to insert. Thanks. |
[2018-08-13 20:56:35] |
John - SC Support - Posts: 31743 |
Yes, you need to put into the Alert formula the actual condition you want to check, in this case, the crossover of the Last price with one of the Pivot Points lines. You will find an example of how to set this up at example # 40 at this link: Study/Chart Alerts And Scanning: Alert Formula Examples The general documentation for entering an alert on a Study can be found here: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
