Date/Time: Tue, 21 May 2024 22:38:13 +0000
EUREX Data
View Count: 870
[2018-08-11 08:26:22] |
miami845 - Posts: 7 |
I am currently on a EUREX data trial & plan to continue as well. I have no problems with dax futures(FDAX), but the Eurostoxx 50 (FESX) is not showing up in the list of symbols. Is that because my trading account is with TD ameritrade. If that is the case, Dax should not have showed up too. If that is not the case, please advise.
[2018-08-11 09:52:39] |
We have to add this symbol for TD Ameritrade. We will do that.
[2018-08-13 07:15:46] |
We have now added all of the EUREX symbols for the TD Ameritrade service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will see them listed in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
