Date/Time: Wed, 22 May 2024 03:36:58 +0000
copying chartbooks to a different installation
View Count: 1131
[2018-08-10 06:53:33] |
User828417 - Posts: 32 |
I've already completed a transfer of settings and data per the instructions under "Transferring Sierra Chart Settings and Data From Existing Installation to New Installation." On an ongoing basis, to copy over charts that I have marked up, do I only need to copy and overwrite the corresponding chartbook.cht files? |
[2018-08-10 23:52:35] |
The answer is yes but just make sure when you overwrite the Chartbook file that it is not open, and then after you can open it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-11 00:28:09
[2018-08-11 21:33:14] |
bradh - Posts: 865 |
You may also want to copy any DLL, SCSS, TWCONFIG, and STUDYCOLLCT files you might have.
