Date/Time: Sun, 05 May 2024 12:34:12 +0000
possible data issue with MHI today
View Count: 620
[2018-08-09 03:22:12] |
johnnykf88 - Posts: 17 |
hi support team, this morning when using the chart of HK MHI (MHI-201808-HKFE), the range bar (50 pts) at 09:30 looked adnormal as you can see in the screenshot: http://www.sierrachart.com/image.php?Image=1533783963127.png if checking HSI-201808-HKFE, there is no problem at that moment. Could you please take a look if there is issue with the data feed? Thanks. JC |
[2018-08-09 04:37:07] |
We have no reason to believe there is any genuine data problem. This is what we see from the SC Exchange Data Feed for that particular symbol: http://www.sierrachart.com/image.php?Image=1533789392340.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-09 04:37:53
