Date/Time: Tue, 30 Apr 2024 12:13:47 +0000
Alerts using fractional price
View Count: 513
[2018-08-08 22:48:19] |
User134590 - Posts: 12 |
Hello, Using an alert for the symbol ZB (30yr Bond) from Chart Settings Panel (Main Price Graph) as follows =BID > 142 25/32 I did not receive an alert with this formula - While investigating this - I tested different values (numerators) I found that if the numerator is numbers 1 thru 9 the alert works (1/32 - 9/32) If the numerator has a double digit - there isn't any alert produced - Also, furthering the test - if I convert the fraction to decimal format (i.e. 142 18/32 = 142.5625) the alert works - please investigate at your convenience - I'm fine converting but I know in the past I have only used fractional notation BTW I'm on v1768 - 64 bit Thanks |
[2018-08-09 01:40:51] |
Sawtooth - Posts: 3985 |
Try this: =BID > 142 + 25/32 |
[2018-08-09 03:22:32] |
Yep, that works also - Thanks much tom |
[2018-08-09 05:35:09] |
Refer to the documentation here about this: Study/Chart Alerts And Scanning: Numbers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
