Date/Time: Sun, 28 Apr 2024 19:35:44 +0000
ACSIL Based on Color Background Alert not working
View Count: 1367
[2018-08-10 01:15:03] |
We need some time before we can get to this.
[2018-08-14 07:59:14] |
It simply is a calculation order issue, and you can see that by the calculation order displayed in the Chart Studies window. The custom study was being calculated before the Color background Based on Alert Condition study. It is solved by doing this: sc.CalculationPrecedence = VERY_LOW_PREC_LEVEL; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-14 08:38:53
[2018-10-14 00:51:51] |
Joel Wisdo1 - Posts: 15 |
Just seeing if there is a solution to this. It appears that if (sc.IsFullRecalculation) return; prevents my SMS Alerts from launching. I inserted sc.CalculationPrecedence = VERY_LOW_PREC_LEVEL; into my SC Defaults but my SMS alerts still will not launch. If I do not use (sc.IsFullRecalculation) return; when I load my study the criteria to send SMS alerts is true and I receive a lot of SMS alerts.
[2018-10-14 01:26:57] |
prevents my SMS Alerts from launching Does the study use automatic looping?
