Date/Time: Wed, 08 May 2024 09:17:55 +0000
Daily bar data max
View Count: 924
[2018-08-08 11:32:37] |
Eric C - Posts: 5 |
I am attempting to download bar data going back as long as possible. Ideally I'd like to see 20 years. I seem to be only able to download 3,000 plus bars with a historical charts and only up to 1300 or so with an intraday chart. Is there a limit on how much historical data there is available based on my subscription?Thanks
[2018-08-08 17:47:36] |
The amount of historical data depends upon the symbol and also the particular service being used. We see you are using Rithmic. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Since Rithmic symbols use single digit years there is a limit to how far back an Intraday chart can go. You will need to use the Sierra Chart Historical Data Service instead for this data. This is explained here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Single Digit Year Limitation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 17:48:02
