Date/Time: Sun, 05 May 2024 11:22:19 +0000
Issue on Multiple Copies of Studies Using PersistentPointer for Storing Objects
View Count: 511
[2018-08-07 19:21:29] |
BlakJak - Posts: 108 |
Hi, I am using GetPersistentPointer() to store and retrieve a copy of my object from call to call and it is working fine on one chart. As soon as I add the same study to another chart, both studies stop working properly. How is memory handled in the case of multiple copies of a study running concurrently? Is it safe to use two copies and GetPeristentPointer()? Rgds, David |
[2018-08-07 20:31:00] |
The data held by GetPersistentPointer is completely separate for each individual study instance. So if you have a problem you have to check your code. Something is wrong on your side. If you are also allocating your own memory you must have sc.FreeDLL = 0
